Bashepard
Ictalurus said:Bashepard
Your boat looks great, and that 40 seems to push it quite well. Although probably not essential, you may want to drop some deck supports down from your braces, maybe somewhere near the seat post. And you also may want to consider slapping three to four good thick coats of spar urethane on the wood as opposed to the Thompson's. As far as the carpet, I have used outdoor carpet glue from Lowe's on two builds with no problems, just wrapped around with an extra two inches and stapled it down. Can't wait to see the finished product.
Thanks for the input, however im on a budget and already had the TWS laying around so i soaked it on. Also, i made the deck so that it is removeable. I will be adding those supports you mentioned when i add the seat plates later.
