yeah I need a jackplate to raise it up and give it some decent setback. Once I get it higher up and into cleaner water it should pick up a few mph.boater1234 said:Hey minicuda thanks for the info.What do u mean by your motor sits to low do u have a longshaft motor on a 15"transom?or do u need a small jackplate to make it even higher just curious.
about 5 inches or so... you can kind of see it in my sig picboater1234 said:How far is the cavitation plate from the bottom of the boat?
kbkid said:The boat is only rated for 35HP. If I were you, I'd get the largest motor you can afford.
