Country Dave
Jonboat Jerry said:Nice layout, looks like most of the weight is in the center.
I had the same problem, the ribs on my boat were packed with oak leaves and I couldn't get them out.Mrtoler said:I noticed after cleaning I took the water hose and really sprayed the inside down and most of the channels for drainage where plugged under the supports...I took the nozzle on the hose and flushed most of them out pretty easily but towards the reattach they are plugged tight and the design dosent really make sence either, but I can fix that. My other question is what is the main reason for steelflexing the bottom of the boat? I see alot of people do it but I've never really heard a reason why?
I drilled a 1/4" hole in the top of each rib and inserted the nozzle of my compressor and blew the leaves out.
That also left a hole for any moisture to dry out. I have not sealed any areas on my boat because of corrosion.
Steel Flex makes the hull quieter and the lighter colors are cooler in the summer. M2C
Thumbs up on the steel flex.
