BeerMe
Johnny said:have you ever seen cars that have been sprayed with primer only
and the brown rust is coming right through the primer like a cancer ?
primer is not a paint or protection agent . . . it is to prime the metal
surface to provide compatible adhesion for the top coat.
The top coat itself is what protects the metal - not the primer.
Primer alone will only slow the inevitable corrosion that WILL form behind the wood.
It may take months or years, depending on the exposure to the elements.
Salt water will only compound the problem.
Maybe I am wrong, but, I honestly think you should remove the transom board
and apply a good quality top coat. Just because nobody will see it is a short cut
that "may" (or may not) come back to bite you.
Totally your call.
https://www.tinboats.net/primer-and-paint-basics/
Thank you for the input. It is appreciated. This is aluminum however and not sheet metal. The aluminum was well cleaned and not a bit of corrosion was present when primed. There is also a ring of 5200 around the perimeter sealing off most (i hope) moisture from getting behind the board. This board is old (but solid) anyway so if 10 years from now i have to pull it again i will replace it in the process. Anyone else have any thoughts on this? Hindsight is always 20/20 but im not ready to pull it back apart just yet.
