Decatur
GREAT finished project! =D>
vanbc said:nice looing boat !!!!! how did you attach the deck and the flooring? Did you screw the plywood into the suports then carpet over top ? Are they removable and secure.
Report this postReply with quote
Hey Stiglitz,
I have a few questions...
BTW, this is an awesome site, thank you fellows for sharing all you do...
1) Where did you get the aluminum angle bar (L shape)? I checked my local hardware store and they want like $17 for 7 ft 1x1x.58...I said what? and I will keep looking
2) I have exactly the same boat you have and I will use your project as my template, I have a few parts missing though, the top of the boat's wall, the trim where your bimini is attached to, where do I get that? You know, the part where the oars holder is attached to. Also, my stern bracket is missing (the part where the front light is attached to) do you know where I can get these parts?
3) How did you figure the height of the floor, how high from the bottom of the boat is it?
4) again, where did you get the decking brackets, it looks like square aluminum tube just cut at the edges
1. Is yours a 12' Sea King? I didn't see where you had stated the length or if you did I missed it.
2. Could you tell me your dimensions and max. weight capacities (limits).
3. Now, that you have been out on the water with it...how does it ride with all the mods? Is it tippy?
[url=https://www.tinboats.net/forum/viewtopic.php?p=164367#p164367 said:Sgt. Stiglitz » 14 Oct 2010, 00:08[/url]"]Yea blue and gray would look nice. I don't know what paints you guys use on the outsides. I would get a sprayer as I already have a compressor. I dont think I want to rattle can it........My charcoal gray carpet should be here this weekend. I will have the wood work ready for it when it comes. So far I have used a gallon and a quart of carpet glue! I put a hatch(screw off) over the gas tank last night. I want to hinge my side storage areas but they are not square and follow the curves of the boat. I don't know how that would play into the solution......
Thanks.
He did a nice job on it. Just finished reading thru the entire thread.[url=https://www.tinboats.net/forum/viewtopic.php?p=363942#p363942 said:bobberboy » August 20th, 2014, 3:25 pm[/url]"]This boat was referenced in another thread and I thought I'd bump it back into circulation. What a nice job. Well planned and well done.
