1961 Starcraft 15' Jet Star conversion
kmercury
Well, I sold my modified 14' Sea Nymph (https://www.tinboats.net/forum/viewtopic.php?f=21&t=15825&p=164107&hilit=kmercury#p164107) last fall after a good season of fishing in the hopes of finding a little larger boat. My requirements were something to house a nice casting deck, remote controls and large enough motor to pull a tube. I came accross this boat sitting in a yard about 3 months ago. It came with a 1973 long shaft 40hp Johnson even though it has a 15" transom.
I purchased it a month later for less than $400. Since, I have been working to just get it operational:
[*]Replaced cut tire
[*]Replace both trailer axle bearings (they were rusted solid)
[*]Cut down trailer tongue due to it being bent and replaced the hitch coupler and safety chains
[*]Rewired trailer lights
[*]Converted the 1973 Johnson from a long shaft to a short shaft, tune up and new impeller
[*]Converted the cable and pulley system from running down both gunnels to right side only.
[*]Fish, fish, fish (nice 10 1/2" Perch last weekend
Now its time for boat overhaul. Plans:
I plan to follow this modification to a point (https://forums.iboats.com/showthread.php?t=455193&s=5ea8f3c4f1ad9c18974dca4017712af8) with some differneces.
[*]Pop the bow cover off
[*]Deck entire boat with upper casting deck
[*]Possibly move fuel tank to front
[*]Pedestal seats all around
[*]Possible livewell depending on $$
[*]Etc.
I have the boat pretty much gutted and ready to cut the bow cover off.....
I plan to use this boat during modification so work may be slow....
I think its a great boat for modification... hopefully those years of wood and metal shop will pay off!!!!
I'm not sure but i might have the same boat. The registration for my boat says 0000 Starcraft and thats it! I have my boat gutted and flipped over right now so i'll be very interested in seeing what you do to your boat. If i get more time I'll start a tread of my own, maybe we can help each other.
I'll try to post a pic later.
Here's my boat. Do you think it's the same boat?
Yep, that looks like a Jet Star. In the left back corner of the boat near the transom well there should be a plate that has the serial number and model of boat. From that, you should be able to get the exact year.
I will be watching yours as well. I cut my bow cover off and now have to deal with those sharp edges. I have a couple ideas and should be able to post my solution with pics this weekend.
Good luck.
Well, got about 30min in on the boat today. As you can see in pic b5 above, when I cut the bow cap off I left about 3/4" extra extending into the boat from the stock curve. Today I cut slits in that extra and bent it down 90 degrees with some hand seamers so I have something to rivet a piece of aluminum fascia to. I also found some great vinyl angle at HD that is used as external house trim. I will use as my trim to cover the sharp edges.. It is a lot cheeper that aluminum angle....
More to come....
Here is the left side finished. Included is a pic of the right side... kind of a before and after.
Not too shabby!
I would love to change but no cash for that right now. The boat is rated to 50hp so some day a nice 4 stroke with tilt/trim will be hanging off the back. For now the old 40hp will have to do.
Got the right side done. Now that those sharp edges are taken care of, I can get to work on the decking frame...
Well, I was finally able to get back to work on the boat. The next step was to get the main portion of the deck installed. I started with a 2x6x8 as my main beam to hold my cross members. I cut it leingth-wise at an angle to get the deck level compaired to the angle of the hull. Next, I cut my cross members. I stapled pieces of rubber innertube on all of the parts that touch the boat hull. I am hoping this will cut down on any vibration.
From here I got stuck. I comtemplated deck material for about a week. I initially was going to use 1/2" treated ply but it is heavy and I knew I would have to cover it with carpet to protect bare feet right away. Since this boat is going in stages based on $$ and I want to use it asap, I needed a material that I could install without the need of covering right away. I thought of 5/4 decking boards but those suckers are very heavy as well. I finally found some 1x4x8 furring strips at Lowes that fit the bill. They were cheep (less than $2 per board) they seemed to have a sanded finish and the corners were milled off, perfect!
I soaked them all with a multisurface water sealer with my lawn sprayer and installed them. I think they look nice and will allow water to drain beneith the deck and keep it dry. I may paint them for now and carpet them in the future.
So, on to the casting deck framing now.
Pics comming soon.
Here is the front deck framing. I need to add some floatation foam and a storage compartment to it, then install. Then its on to the seats and console.
I framed in the small storage area under the casting deck and then moved to the foam. This large block was installed under the bow cover originally on the boat. I did some trimming and bungy corrded it onto the deck frame. All installed and ready to go.
Neat interpretation of the phrase "deck boat"! :mrgreen: It will be interesting to watch your progress. Are you going to add some more foam under the flooring? (had to ask! :wink: )
Yes, the Lund shown is what I am going for but mine will have seats instead of pads at some point and a full rear bench. The seat boxes will be filled and the bench lined with foam.
Casting deck is now on. I am going to paint the deck then get to work on the seat boxes.
I am not too sure, I should estimatethat out... maybe 50-60lbs so far. Those 1x4 boards are quite light. In thinking about this, if I had gone with treated ply, carpet and etc, it probably would double that amount. I pushed the boat around last night and it did not seem too much heaver.
I got about half the desk painted. The side walls are a slate gray and the deck a light gray. I am going for 3 coats and will see how that does. Then, on to the seats.
Deck fully painted today. Now on to the seats.
That looks great, are you putting anything else down, if not, are you worried about stuff falling through the cracks?
