- Joined
- May 26, 2023
- Messages
- 43
- Reaction score
- 43
- LOCATION
- Slatington, PA
Pappy, I did not remove that or any of the Welch plugs. I did spray carb cleaner through the passageway leading to the cavity and saw it exiting the 5or6 small holes in the top of the carb. I took a short cut and am now regretting it because I cannot say with certainty that the cavity and holes are not blocked.
I did remove and clean the high speed jet. I did replace the lift tube seal.
My inclination now is to remove the carb and go back through it ( including the removal of the Welch plugs) so I can say with great certainty what’s what. Additionally, and as mentioned above, I’ll replace the 25 year old bulb and hose and start over with fresh fuel mix. I’ll let you know how it goes and what I find…but that won’t be for several weeks as I’ll be out of country for some time.
Thanks all.
Thanks all.
