parratt1 said:Is your build on here? I'd love to see it!Captain Ahab said:I used the bench seat brackets with a cross member and L brackets on the ribs on my 16' mirrocraft build
You can see some of it here
https://forum.tinboats.net/viewtopic.php?f=21&t=18404
One thing you do not need to do is build the center box - I did that because of the pedestal seat but realized it was wayyyy overkill
Run the alum L pieces port to starboard with some bracing from the hull below and you will be fine!
Used self tapping alum screws to mount "L" brackets to the ribs and then built up from there - same on the side - "L" brackets held on with SS nuts and bolts
