BAY BEAGLE
This boat has been a part of my life for over 46 years. The owner comming up in age, feels handling a boat of this size is not a option. So I was able to take ownership, and bring it back to life.
Posted a few pics and questions on other post in TINBOATS, but now I'm consolidating them into this thread, as my journey begins ....
I have read for many, many hours the work and techniques You Guys and Gals have put into Your project(s), and took alot of notes along the way. From those notes I have gained confidence that I can turn this "tinboat" around.
BIG THANKS!!!!!!
Heading to the barn -
Converting the Kayak trailer over to the bunk trailer -
Building the bunk trailer -
Trailer situated (boards not yet bolted to frame, carpet will be after boat build
Looking into the weak spots, removing all hardware, making a game plan for the transome -
Survey the "tree limb damage" - and what action to take. From some good feedback - welding is the only option ..... and that will not be a problem.
And to get this rail section straighten/rounded out -
And to correct and smooth out a few "wrinkles" along the way -
Tested the sanding today, to see what grit would attack the original base - winner was - #180 grit paper with orbital palm sander, and NYALOX DISCO 541 - 778 - 4 WHEEL poly #120 brush around rivets and tight area's.
Having a fresh pair (105 days old) of transplanted lungs - my savior was the RESPERATOR, that eliminated those fine particles.
______________________________________________________________________
As I'm working, I'm pondering the next steps regarding seat placement - open floor plan, gas can placement, seating, Bimini top & mount. It will be a 20 H.P. tiller drive w/ front mount electric motor (12v or 24v). Removing the front platform will be one of the first attacks, along with removing the transome and removing the factory primer.
.................... keep You posted. Please chime in for "Your tricks and tips" to make the rebuild last. It needs to be durable in salt water, and comfortable for crabbing and fishing for Speckled Trout & Rockfish.
NOV. 5th .........
Got below freezing last night - filled up the wood stove in the shop, and went to play ...... tearing down more of this rig.
Removed the rivets holding the transome angle brackets. Removed the hardware that attached the transome braces to the floor, and transome wall. Old transome came out in one piece. Looks like 3/4" & 1/2" bonded togeather will match the 1-1/4" needed to replace this. Need to address the cancer on the aluminum, where the transome plywood made contact.
BIG THANKS!!!!!!
NOV. 5th .........
