I have another mini project in the works. I picked up an old trolling motor from a rummage sale and all it needed was a switch and the mount deal was broke so fixed both. I'm working on mounting it up front on the bow of my boat.
First step was to remove the top section to fix the mount and rewrite the switch I also removed the old handle to replace it with a longer one.
You can see in this pic how I fixed the broken mount. I used some plumbing/electrical fittings on the top and bottom to hold it in place. Since its a bow mount it will always be all the way down anyway.
You can see in this pic how I reworked the on/off button to change it to foot control.
Here is the foot pedal construction the only thing left to do is mount it in the boat and finish wiring it.
You can see in this pic the longer handle I made and mounted
It's ready for paint just have to let some glue setup for awhile then prime/paint.
I need to pick up another wiring plug to install like I have in the back so I can just plug it in. I also may brainstorm a way to move the variable speed switch from inside the unit to mount it in a little box so I can control the on/off and speed and forward/reverse without having to move. I'll still have to manually steer though.
Next step is to figure out how to mount it.
Here's what I started with.
