Hello guys my name is Danny and I live in LaGrange, GA, I'm retired =D> and enjoying it highly recommend it.
First thanks to all of you for this forum and the interesting and wealth of knowledge expressed here.
I have been reading all kinds of posts the past few months with a main focus on transom replacement.
And now I'm confident I can do it. I have a 1979 Landau 1648 with a 1984 Jonson 25hp.
I have to figure out how to post the pictures yet.
Wish I could show pictures but not yet.
So far I have drilled out the rivets, removed the knee braces, removed the transom bottom support channel, removed the hull transom supports and was able to remove the rotting transom board intact (that was a relief for a pattern). I've had the knee braces welded back together at the top where they had started splitting in inside corner from the top down for 2".
Got a sheet of Georgia Pacific plywood BC 23/32" (EXTERIOR was stamped in large type on the back side).
Cut it down to a couple inches larger the finished size, lightly sanded the rough sides (glue side), cleaned off dust, laid on carport slab with newspaper under wood, drilled pilot hole for two screws on one end, squirted 8oz bottle of Titebond III all over bottom board (rough side up) and laid the top board down rough side to glue. Screwed the one end together to keep lined up and weighted down with 4 large automotive batteries maybe 60lbs. each and other heavy stuff. I did not remove the screws after glueing I think I read that screws should have been taken out after weight was in place.
Hope I'm not getting to detailed here.
All steps done to this point I've learned how to from you guys and I think that's pretty cool thanks.
Please offer any comments.
I'll post some questions soon.
