1980 evinrude 9.9 starting problems
I didn't get home in time to run motor, but I did find a fuel/oil residue leaking where the fuel line connects to the fuel pump.
When I squeezed the bulb a tiny amount of fuel came out at the leak. I inspected hose and it seems ok.
I replaced the zip tie clamp with a metal clamp. It seems the fuel leak stopped after this.
I guess it could have been sucking air? Ill be home today in time to test it I hope.
Got home and hooked motor to hose. Fired on 3rd pull. Ran good for 15-20 seconds. Sputtered and I pumped bulb. No improvement. Engine died and wouldn't start again.
Pulled plugs. They are wet. Dried them by using a lighter to burn off fuel. Let fuel in cylinder dry out. Motor refired for a few seconds.
Same steps repeated 3 times with same results.
There is also lots of fuel/oil mix on foot. Foot oil is fine. This is gas mix.
Can I assume carbs? Float stuck I guess?
    1.8 MB
    2 MB
Thanks for y'all's help. I had a stuck float causing it to flood out.
Carb rebuild was really simple and I've never done one. Thanks guys!
