lucescoflathead
I don't have a 20 Hp yet. What year would you get? I want to try to get one this summer. Thanks Todd
Johny25 said:Update to my motor not running as well as I wished she had first run. After replacing all my fuel lines I noticed it was drawing fuel and air through the primer line to the intake and spitting fuel threw the line that attaches to the top of the carb while knob is pushed in. See through hoses are awesomeAnyway I am assuming that the O rings are bad inside the primer assembly so I will be removing and rebuilding the manual primer today. This should correct the sputtering and cutting out issue I had the other day.
Johny25 said:Well lucesco I know some of those years you are talking about had different gear cases which could cause a problem when putting 10 to 15 more HP to them. You would have to cross reference to see what the differences are for what year motor you are talking about. I know I was talking to someone with an 80' or 81' and the 20hp of that year has the smaller split gear case than the 35hp. Would hate to see people doing this mod and ripping their gear cases apart so look into it. Or ask and maybe I or another can help you.
Johny25 said:Well if you have a leaky prime like I had just pull the hose going from the prime to the top of the carb while it is running, if there is a lot of fuel spitting out the line while the primer is pushed all the way in then you have a problem. It will spit just a tiny bit or non at all if the primer is good. My bad primer assembly was spitting a lot of fuel into the carb when in the off position which was a big problem getting the motor to run correctly.
