1981 Lowe Superior 14foot V-hull
Rob4
Colorado
Some pics of my winter project. Made it into a brown trout! Third time down this road with various boats. First time with a tin boat. Some fun steps involved; Stripping paint (ugh] cleaning aluminum, rebucking some rivits, Gluviting rivits, dulling down the gulvit, priming, painting, templating decks, planning, then building deck frames, and decks, then painting both twice, fitting hatch doors, wrapping decks with Nautalex vinyl, cutting and attaching piano hinges, and mounting anchor winch. WHEW! Now, on to reattaching graph and accessories and doing some ice fishing, til I can get it back in the water!
    178.4 KB
    74.6 KB
    78.9 KB
    79.1 KB
    70.7 KB
    84.4 KB
    84.8 KB
    106.3 KB
    29 KB
    81.6 KB
Added a couple pics of the anchor winch installed and finished with wiring completed, etc. BTW, I like the Nautolex vinyl so far. Looks durable and just a little more difficult than carpet. The main thing with it is spacing hatches as tight as possible, while not allowing excessive rubbing between door and deck, while opening and closing the hatches. Cut the doors carefully, and allow for the vinyl AND hinge widths. Have both vinyl and hinges on hand before final cutting your hatch doors; to ensure correct spacing. I used two 36"stainless hinges off Amazon, and cut to length with a hack saw too make all 4 hatch hinges.
    149.4 KB
    102.4 KB
Nice, clean job, looks great. I plan on doing something similar with my 14' V-hull as well. Nautalex vinyl as well, that is what came from the factory, I think, and I like it a lot. What did you use for the flooring, 5/8" plywood?
Looking good! I have done similar work on almost all of the 3-bunk boats I've had. Makes them a lot more fishable in my opinion.
I usually put a cap on the center bunk for traction, for when you walk from the front of the boat to the back without going up and down.
Also, I ended up putting a lightweight, flat floor between the bunks on my last one. Just a couple pieces of angle aluminum and a 1/2" wood insert. That was really nice! Now, it felt like a finished boat. Got tired of sliding around on the angled bottom, anytime water got into the boat.
Just some thoughts/ideas, but you have done some very nice work.
Shoulda used 5/8 had 23/32 CDX. Painted it twice, then waterproof carpet cement on top and used 3M 90 spray adhesive and stainless staples for wrapping. It's a slower installation process than carpet, for the wrapping of the vinyl. but only because I was trying to be more careful with the wrapping part to make it look "professional". Do not get any carpet glue on the good side of the vinyl. Paint thinner acetone, lacquer thinner will all remove the color. They might make a product that can take it off if you do.
Good tips! I'm trying to keep weight down at this point, as I used 23/32 for the decks, so will leave the floor as is. Boat has a 725# capacity, so with 15 hp Merc, two people, lithium battery small TM, and gear I'm still fine, but don't wanna push it!
