Bowlershop
If I remember correct, the last time I was out with me and my buddy in there and some gear I got it up to 28 mph.
Are you talking about this top corner cap? If so, yes I had to cut them off and have them welded back on. Thanks for the question, I do have many more pics if that would help.jy951 said:This may be odvious, but did you have to cut off. and re weld the transom corner braces?
I plan on just using sheet foam everywhere. Under the deck where it was blown in from the factory I will cut she foam and stack it up, it worked on my other build. I'm actually going to work on removing the sticker residue today. I'm also going to try the adhesive remover that I used for the carpet. Going to throw all the ideas I can get at it and see what works the best. I also fired the motor up and it ran perfect!!!! Now going to take it to marina for new impeller, prop and lower unit pressure check. I may need a new seal on carb, it was dripping a little.Kingbryce said:Man good job on the rebuild! I wish i would have had the time to blow my tracker apart like this. what are you going to do for the foam under the rear deck? Did the acetone and magic eraser work for removing the sticker residue down the sides of your hull? Those old stripe stickers are something else. The adhesive they leave behind is a living nighmare.
