Johny25
Get more weight up front if you can.......will help the porpoising
[url=https://www.tinboats.net/forum/viewtopic.php?p=343374#p343374 said:Siguz » 19 minutes ago[/url]"]Hi,
I'm new to this forum.
I came across it while looking for a a way to boost the power from my 1989 Evinrude 20hp.
I want to do this manifold modification but I am afraid that no one will work on my motor afterwards.
I'm just starting to learn about small engines but have been working with cars for over 10 years.
What has to be done after the intake bore?
-Does the timing have to be set differently or anything like that?
I don't want to end up in a spot where regular maintenance is not enough for the motor after it has been changed.
Any input is appreciated.
Thanks!
Stefan said:[url=<a class="vglnk" title="Link added by VigLink" target="_blank" rel="nofollow" href="https://www.tinboats.net/forum/viewtopic.php?p=343374#p343374 said:Siguz"><span>https</span><span>://</span><span>www</span><span>.</span><span>tinboats</span><span>.</span><span>net</span><span>/</span><span>forum</span><span>/</span><span>viewtopic</span><span>.</span><span>php</span><span>?</span><span>p</span><span>=</span><span>343374</span><span>#</span><span>p343374</span><span>]</span><span>Siguz</span></a> » 19 minutes ago[/url]"]Hi,
Thanks!
Hey,
It depends on the model, year and size of the motor. In my case, the 20 hp was = to the 25, 30 and 35 hp of that vintage. the only difference was the intake manifold and carb for the 30 and 35hp, and for the 25 hp model the only difference was the intake manifold.
I didnt have to do any further modifications to the engine to get the increased power.
Again, do your homework on the specific motor you would be modding. Luckily for me , my engine shared a powerhead and gearing with many different motors.
[url=https://www.tinboats.net/forum/viewtopic.php?p=353935#p353935 said:Johny25 » Today, 19:20[/url]"]Ok hold up! I am sorry but I have to interject some knowledge here. First off the dolphin will not help top speed at all.....sorry. It helps keep boat on plane at lower speed and helps boat plane out, no top end increase. In fact it can do the opposite to top speed if not set up correctly.
Second if you want the correct prop to get top speed then post your current prop specs, RPM, GPS speed and make and model of motor. This will let me know your gear ratio and recommended RPM for the motor to give you a better idea of correct prop now that you did mods to engine.
DO NOT BUY A PROP BECAUSE SOMEONE TOLD YOU OVER THE PHONE IT WOULD BE OK! TRUST ME.....You have a high risk of wasting your money and messing up your motor. They are designed to run at a specific RPM range and just guessing without proper info can take away life of your motor or ruin it entirely
[url=https://www.tinboats.net/forum/viewtopic.php?p=353949#p353949 said:Stefan » 28 May 2014, 21:47[/url]"][url=https://www.tinboats.net/forum/viewtopic.php?p=353935#p353935 said:Johny25 » Today, 19:20[/url]"]Ok hold up! I am sorry but I have to interject some knowledge here. First off the dolphin will not help top speed at all.....sorry. It helps keep boat on plane at lower speed and helps boat plane out, no top end increase. In fact it can do the opposite to top speed if not set up correctly.
Johny25, thanks for imparting your knowledge. I've read numerous of your posts and I know your knowledge of these motors is extensive to say the least.
This is motivating me to replace the prop on my engine. You say that you need the RPM at top speed with current prop.. How do I go about measuring RPM? Is there an aftermarket Tacho tool you can buy and attach to the outboard to give a reading? I've seen them for motorcycles, but is there something similar for outboards? If so, where is the best place to buy these?
