[url=https://www.tinboats.net/forum/viewtopic.php?p=354700#p354700 said:
Johny25 » 04 Jun 2014, 16:57[/url]"]Is this how heavy your boat is the majority of the time or do you add more weight usually?
Your numbers come out as follows.....(assuming you are doing 23.5mph still?) you gave RPM and no mph/kph reading so I am going to assume here.
10X13 prop (aluminum?), with a 2.15:1 gear ratio at 5295 RPM and 23.5mph gives you a slip of about 22% which is NOT great by any means. Better to be around 15% on these smaller motors.
My suggestion is if you are going to run any more weight in the boat you definitely have to go down in pitch. A 10X12 prop should get you around the 5500 mark with current setup. Your holeshot will improve and slip will likely drop a bit also. Your speed will not increase though.
If you had bought that 15 pitch you would have lost 400rpm and lugged your motor out. likely not gaining any speed and having a slip number in the upper 20's
Note: this is all speculation as every prop manufacturer has different blade design, rake and cupping which effects RPM and performance. If you go to a stainless prop you may get better performance and RPM with the same pitch prop. But if it has aggressive cupping then it will lower your RPM for same pitch.
I run a 10X14 solas saturn stainless on my 14' Lowe and my boat is pretty heavy with the decking I put in. Sounds like your boat is even heavier and you would not be able to turn a prop that high in pitch.
