there are a few Thread Repair kits on the market. as well as a couple from Loctite.
do your research and see what you feel comfortable with. I picked the 3967
just because it was recommended on a few auto repair websites I visited.
LOCTITE® PC 3967™ Stripped Thread Repair Kit makes reliable thread repairs
without drills, taps, tools, or inserts. Restores worn, stripped or damaged threads
and eliminates future corrosion, galling, seizing, and rust. Allows up to 128 ft. lbs. of torque
between -65°F to 300°F. Permanently repairs stripped threads and fasteners in five minutes.
Typical Applications: Intake manifold bracket fastener threads, timing chain cover bolt threads,
valve cover bolt threads, water pump bolt threads.
this stuff sets up in five minutes !! so you don't have time to dilly-dally around.
do a test subject prior to actual application on your boat.
