edwonbass
Oh yeah, and your build is coming along nice!
gatorglenn said:I agree, you would be good on the decks.![]()
This is where I at now. Doing a re fresh. How you make your deadline [emoji106]
Thanks. Yeah I'm pushing it nowgatorglenn said:That's supposed to say I hope you make your deadline good luck
Prowelder said:I got a 8.5ft x 20ft roll with 2 gallons of glue for less than $300. The countdown is on. I'm trying to finish it in 11 days.
What happened with the glue I have glued a couple of pieces with it and it seems to be very strong on the aluminumDPI said:Prowelder said:I got a 8.5ft x 20ft roll with 2 gallons of glue for less than $300. The countdown is on. I'm trying to finish it in 11 days.
A couple things I learned the hard way:
The glue boatcarpetbuy sells by the gallon is not for aluminum and I used about 240 sq ft of carpet on my pro175 with very little waste.
Bcb recommends a solvent based adhesive for aluminum, ie contact cement.
I just cleaned it and wiped it down with acetone and spray painted it with high heat enamel.gatorglenn said:Looking great! What paint is that on the console. Did you have to primer the console first. what process did you use
ThanksCody87 said:Your side rails turned out really nice. Great job man.
Thanks great jobProwelder said:I just cleaned it and wiped it down with acetone and spray painted it with high heat enamel.gatorglenn said:Looking great! What paint is that on the console. Did you have to primer the console first. what process did you use
Sent from my SM-G920T using Tapatalk
