Went fishing today and my motor ran good going to the fishing area also idled around the area good. But on the way back to the ramp it ran like it was not getting enough fuel and it would not get on plane even after I squeezed the primer bulb. The primer bulb was not hard and I squeezed it twice . When I got it on the trailer I unhooked the fuel line like always to run the fuel out of the Carb and it died instantly.
After thinking about this I am wondering if the fuel pump has gone bad. When I pulled the hood off all around the fuel pump was wet and smelled of fuel.
I have never replaced the fuel pump and have owned this motor for about 3 to 4 years. I felt the plug wires and did not notice any obvious nicks or cuts so don't think it is a firing issue.
My question is does a fuel pump work a little bit or does it just go bad and doesn't run at all?
And what else should I look at?
The hose from the tank to the motor is black if that makes a difference.
Thanks for any help.
Jon
Jon
