Thanks ,it runs as good as it looks to. I run wot near 80% or more of the time. I just don't want people to think ok,get on the water and hammer it. I get to the ramp and warm up for 5 minutes every time, then I idle for like a few minutes it takes to get out of the channel,once I get past the resume as Normal from the no wake zone then I hammer it so the motor is 100% properly warmed up is thee most important thing to do before running it. I just know from reading and reading and I talk to lots of boaters and outboard techs and they say you have one time and one time only to seat those rings,the good part is today's technology and computers that help the workers put these engine blocks together, the tolerances are so close compared to the past that almost little to no break in is even needed anymore according to the article I have read on mercury marine actual website. Like I said people can do as they want,it's their dime and I understand,but the thing I see so much and it scares so many people is they think if they don't break in an engine the way the book says they can,void my warranty if I have an issue, that is so far from the truth. Again it is only a recommendation and nothing more. It does not say anywhere in my manual or any manual I've owned from new,if you don't break it in the way we recommend we will void your warranty. If an outboard is a lemon from the start whether it's ran hard or easy won't change anything,good part is as many as they produce your lucky if 1 to 2% are ever bad,so 1 out of 100 could possibly have an issue if that.gatorglenn said:Sweet looking motor. And I totally agree with your break in also. One thing to remember on any 4S outboard is to WOT it a few minutes on every outing. At the end of your day, before loading at ramp. This is actually a cleaning. Doing this will keep that dreaded carbon buildup from happening. This is and was the biggest problem boaters had when 4S first hit the water. Especially if you're going to be trolling. It is essential that you do a few minutes of wide-open throttle before loading the boat up on the trailer.
All that aside,lol,I can't wait to see how good this puppy runs on my new boat. I have ran my original one on a 1436 that was the heavyweight Lowe that is 205lbs, I had me at 325lbs at the time,friend at 220lbs,boat 205lbs,engine at 97lbs,coolers,tackle,etc....so it was 1000+ lbs on a 1436,not a good idea,lol,but it hit 27mph and I couldn't believe it. The wider the boat the better it planes so I expect near the same give or take a mph or so. As soon as I hit the water I will post the speeds for anyone looking to purchase this outboard. Sorry so long.
