23 mph is what I got
hotshotinn
My 1448 going down stream I got 23 mph on my hand held gps.At one point I got 24 but that was a fluke.Going up stream I got 20mph.You think this is good or bad for a 1448 with a 25/20 Johnson?Just me and one big deep cycle battery.Maybe a 40/30 would really make it skim along better but i have to find one.I fish most of time by myself and I am not in a hurry so the 25/20 will works till I find a 40/30
That speed is pretty good. I have a 1448 with a 25/20 Merc. I get about 20-21 mph. Mine has an aluminum floor and that was with tackle and fishing equipment.
Scott
I just cut some 1/8 inch wood to raise up the motor.I figure 1/8 at a time then use GPS to see if gains in speed.Cant hurt anything to see
Maybe 28 with a prop but with a jet?
I should run it without a battery so the boat is at its lightest point,then GPS
ya, i dont know how you could squeeze 28 mph out of the small sized jet pump. my dad has a 1448 tracker with a 25/20 mercury jet, no decking with a starting battery and 6 gallon gas tank, and the motor raised as high as it will allow without cavitation.. it only runs 22mph gps. same for my 1648 lowe big jon with a 30hp rude converted to a jet, with just me it moves at about 22mph on the lake with no wind.
I am running a 17/52 Xterminator and with the old STOCK 40/30 Johnson it would run 23 GPS on lake with two people and with the new STOCK E-TEC 60/40 it runs 28-29 GPS on lake. Down stream on river around 31-32 but that's tops. I do have a full load of fishing equip.
I think I am at all I will get but it sure willnot hurt to play around some to see if more speed can be had.I will start in with 1/8 raise to start,then add another 1/8 inch.Even one or two mile per hour would be huge when dealing with such small horse power
Just for reference, my 15HP Nissan on a 14' Lowe Superior V-bottom does 22mph, on flat water, no wind, using a stop watch.
well, 28 is fast for a 20 jet my 15/48 grumman only ran 28 tops with a 25 rude.
when switched to a merc 20 jet only got 22 top down river loaded.
I got my lifting up shims all cut and now I am waiting for the river to go down.River is all flooded real high because of the rain #-o
