LOL way to revive an old thread that needs a fresh review !!
and :WELCOME:
I can tell you this from my personal experience . . . .
100% clear GE Silicone and other adhesive/sealants applied to BARE aluminum
will EAT THROUGH that area rather quickly, maybe 6 months to a year.
Luckily, I did not toss some old pics of the hassle I just went through with the same issue.
This topic probably deserves a new thread - to start fresh. But here is what I discovered
when I removed all the transducers from my bass boat to resurface the transom.
Just to clarify some things - - - - with the GE Silicone, it is a very aggressive sealant and adhesive.
BUT, it has some inherent bad qualities that brings corrosion to the table.
And, when I removed the transducer, I was flabbergastedly shocked that the 3M-5200 caused corrosion
on the bare aluminum.
Ok, history: the boat was used 99% in fresh water lakes. Only 2 or 3 times in "less than fresh" water in 3 years.
Preserving the aluminum prior to installing items is another story all together.
Welcome aboard - use the
SEARCH button to find all sorts of information.
to answer your question - - - the product
itself will last forever in salt water.
it is the
substrate, (aluminum) if not properly prepared prior to application, that will give you
GRIEF !!!
