Douglasdzaster
- Joined
- Sep 19, 2020
- Messages
- 780
- Reaction score
- 459
- Location
- Smithville,Texas
- LOCATION
- Smithville, Texas
I don’t know if or how bad a problem I have. I’ve turned wrenches for a long time but this is my first outboard and it’s been a project. I’ve had it running for a while now so I guess it was time. First thing I did was replace the water pump and change the lower unit oil. But that’s the extent of my knowledge when it comes to the lower parts. I was running it in a tank today to check out an idling issue. The hose popped out of the tank so I got down to put it back. Then I noticed water was coming from around the shift rod where it comes out of the lower unit. And directly in front of that is a hole I thought was for draining water when tilting the motor. Water was shooting out of that more than the tale tail. The upper exhaust port had a good amount coming out of it as well. The thermostat is new and the motor was running just under operating temperature probably because of the cool water I had running in the tank.I don’t know how normal any of this is but it doesn’t seem right to me so here I am looking for advice. If there’s a problem I want to fix it before going back to the lake or river. Any ideas or advice is always appreciated. Thanks
