phased
ben2go I finally received an e-mail from Rupp Parts on parts availability on your gamefisher. I sent you a PM with the info.
phased said:ben2go I finally received an e-mail from Rupp Parts on parts availability on your gamefisher. I sent you a PM with the info.
phased said:Keep us posted on the new valve. Hope it works for you.
phased said:Congrats on your find. I know that is a load off your mind.
i got better ways to keep them from walking away with my stuffben2go said:phased said:Congrats on your find. I know that is a load off your mind.
Thanks and yes it is.Now when I get it running I gotta locate a good 3 gallon plastic fuel tank,line,and female coupler.I got the male coupler.It's bolted to the lower cowl pointing out next to the tiller arm.If this was a big motor that I leave on the boat,I'd skip the connector and run the line straight to the carb.Most tanks have a connector between the tank and fuel line.I remove and store my motor,in my building, after every use.Keeps the neighbor crack heads from walking off with it.
