RaisedByWolves
Did you miss the part where I added oil to the cylinder and the compression went into the normal range?
RaisedByWolves said:Did you miss the part where I added oil to the cylinder and the compression went into the normal range?
RaisedByWolves said:I worked on a coworkers family hand me down motor, carb kit/impeller and reseal of the lower unit.
Unfortunately after I worked on it, he worked on it........dont ask, hes a bonehead.
Anyway, the motor starts and idles fine, low speed running is great, but thats all that it will do.
It only pushes his 14' boat @ about 3mph.
The motor sounds good, but it just wont rev out and bring the boat up on plane.
Where would you start.
He is referring to the carb gasket I believe.RaisedByWolves said:MrGiggles said:I believe on those OMCs, the orifice for the main jet is in the bowl of the carb, not in the main body like most. There is a rubber donut gasket that seals the two together. If that is missing, it will idle all day but totally fall on it's face when revved. The plugs will be wet and it may flood out. Make sure it's there and in good shape.
Im not seeing an o-ring on this diagram.
Pappy, I took it out and ran it solo and there was no bog, it just revved to a certain point and stayed there.
I added choke with no change. Well, it did die off a lil like it was going over rich but no change for the better.
I pumped the ball with no change.
Checked it was firing on both cylinders.
I did read on THT that there were some bad pump diaphragms from sierra so Im going to change that out and see if there is any change, but I would think that would have shown its self when I pumped the ball?
Stumped.
RaisedByWolves said:Just went out to double check compression and it dont look good.
75 cold that bumped to over 90 with oil in the cylinder.![]()
newyota said:RaisedByWolves said:Just went out to double check compression and it dont look good.
Good compression is 75.
ClemsonAlum said:One more easy item to check: Look at the kill wire where it is held in place to the housing by a washer type piece. The one on my motor had bad insulation (original wire) and rubbed off from vibration, grounding out the coils partially. I replaced mine and saw some power gain.![]()
-Kurt
1436 PolarKraft & 9.5 Evinrude
Pappy said:A "perfectly healthy" engine will not have a 20# increase in compression with the simple addition of oil to the cylinder.
A long hose on a compression ga. should not affect the reading. The gauge should be calibrated for that volume.
What WILL have an effect on any compression gauge is the substitution of of a different Shrader valve other than an original replacement. Shrader valves are not all the same. Far from it. They all have different spring pressures internally and therefore different pop=off pressures. These differences will produce vastly different readings from the valve the gauge came with.
I went through Hell trying to get an original for my MAC Tools compression gauge (with hose). The Shrader valve blew in it and most common replacements would give me low readings. The other mechanic at the shop just happens to have an identical MAC Tools gauge to mine. I kept learning about different Shrader valves and finally found the right one that would match numbers to a known good gauge.
Keep this in mind when playing with compression gauges.
RaisedByWolves said:newyota said:RaisedByWolves said:Just went out to double check compression and it dont look good.
How do you account for no change in power regardless of what’s done to it.
If it was fuel it should have responded to adding choke, but it didn’t pick up at all, it only bogged near full choke.
Main jet was removed for carb rebuild.
MrGiggles said:Pappy said:A "perfectly healthy" engine will not have a 20# increase in compression with the simple addition of oil to the cylinder.
Depends on what oil, how much, and other factors. There are no hard and fast rules and too many variables to strictly say that the engine is junk just from a wet compression test, performed by somebody else.
Hose length will make a difference. A simple calibration in the gauge will not cover all situations, it would read normal on small engines, and high in automotive, or vice versa.
The volume of the hose between the schrader valve and the piston effectively increases the combustion chamber volume, on an engine of larger displacement, it doesn't make much of a difference, but on a small engine, those few extra CCs do. For small engines, you need a hose adapter with the schrader placed right about where the spark plug electrode would be, hose length after the schrader has no affect, will just take more or less pulls to get a peak reading.
newyota said:RaisedByWolves said:newyota said:Good compression is 75.
How about a clogged exhaust port?Have heard of heavy build up causing this reducing flow.Then again it may still get to proper rpms,but lose power?Does it have the right prop on it? Have you checked the rpms on it.I use a tiny tach for my 20hp to aid in troubleshooting and set up.
RaisedByWolves said:MrGiggles said:Pappy said:A "perfectly healthy" engine will not have a 20# increase in compression with the simple addition of oil to the cylinder.
How is the hose length going to affect a wet vs dry compression test.
Ive studied automechanisc and have worked on engines all my life and never heard ant talk of what type of oil to use other than simply motor oil.
The oil I used was even lighter, probably about 10wt machine oil.
If you dont have this oil/oiler, get some.
The empty bottle and extendible spout make this a great tool to prime and engine for a quick start and to check and eliminate fuel delivery issues.
Extend the spout, squeeze the bottle then put spout into container of gas and let it suck gas out of tank. You now have a couple ounces of fuel to prime an engine, light a fire, soak your sneaker with. :shock:
