7.5 evinrude throttle problems..
.:Crosby:.
Bass Capitol, Florida
the motor..7.5 rude not sure exact year 80's i would guess
the problem..when i twist the throttle handle it will only rev up so far then it feels like it slips. i can take the cover off and push the throttle to WOT and hold pressure on the throttle handle and it will stay at WOT for a little while, but then feels like it slips back down slowly. The tiller handle has a throttle cable, not a solid rod, of that helps any. preciate the help!
Try these links to figure out the year of your motor.
https://www.sschapterpsa.com/ramblings/omc_model_code.htm (1979 to 2007)
https://www.marineengine.com/manuals/johnson/ (pre 1979 Johnson outboards)
https://www.marineengine.com/manuals/evinrude/ (pre 1979 Evinrude outboards)
You should be able to find the model and serial number near the tiller hand and transom bracket.
When you find your year and model of motor then check out the link below to help with care and repair.
It is a Free service and open to public and LOADED with helpful Information, Manuals, Service data etc..!
Go to: https://search.ebscohost.com/
Log in with:
P.W. : public
-----Go under the Small Engine Repair Reference Center
-----Then select Marine/Boat motors
----- EVINRUDE/JOHNSON
Scroll through the list of makers/manufacturers
Search by type, brand, etc. They are all in PDF format so you can save them for future refference....
Hope this helps you out!!
cajuncook1
