FishingMedicTn
Well if I knew who who BassBoy was 4 years ago I probably would have bought a Johnyrude . My old merc 110 started having trouble today. It idled rougher than normal an then started choking out at speed. Well I started fooling with it and noticed the impeller wasnt working (It was working the day before). I immediately shut it down and limped back to shore with the trolling motor. When I got home I took the cover off the motor and noticed gas would leak out from behind the plastic choke/run piece when I tilted the motor forward. I pulled the fuel pump off in preparation to pull the carb out but chickened out because Ive never done it before. I dont have a manual and I figure I need to buy a carb kit before I start. Plus I should change the impeller first so I dont burn up the engine . Im assuming I should chase down the gas leak. And Im assuming its somewhere in the carb or is there something else that would leak gas through that plastic piece that moves to choke or run? Is there a Free manual or tutorial online that would help me or am I going to have to buy a manual or worse take it to a boat shop? Oh and this is my first post to tinboats. ive been devouring this site for about a month now. Thanks for any Help
