Looking at at set up that includes a 9 1/2 Evinrude. I can't see it run(too far away) and don't want to chase a possible money pit. I asked my servicing dealer about it with a pic and below was his response. My first reaction was.... ouch! I know it is impossible to tell without him opening up, but would this be a big gamble? Below was his reply to my asking his opinion.
"9 1/2 is some where between a 1964-73 (years Johnson Evinrude built the 9 1/2) parts are no problem. That motor had a bellows on the exhaust that will cause exhaust to be pulled into the engine making the motor run crappy. It can be fixed. The way to check this is pull the cover of the motor off and check the foam on the underside of the hood. If is dirty looking, exhaust is getting in the motor. This can be fixed. We have done a bunch of them. I would figure you’ll have a water pump kit or impeller, tune-up kit, carb kit (there are some mods that need to be done and I assume they have not) and fix the exhaust bellows/leak. Money wise I figure worse case, $600.00 or less. Get the model number and I can tell you what year the motor is"
He didn't state what the best case scenario would be. Thought I would get some input here before going back to him. I can't imagine putting any where near $600 into a 40+ year old motor.
