blugoose
I bought a 14' Bass Tracker topper it came with a 8 horse Johnson. Motor is very clean and seems to have been well maintained. I bought the boat to use on local lakes that are electric only so I did not really care about the outboard.
Today we tried to get it started, the previous owner said it had sat for 2 yrs. but that he did run the carbs dry before storing.
I'm sure my problem has come up before but I can't find it. It started after several tries ran pretty good but the stream is very weak , have to replace the impeller and maybe rebuild the water pump.
Like I said it started after choking it like crazy and finally ran at idle when we shut it down and tried again we had to choke it again I know once they warm up you should not have to choke them to get them running.
Any ideas.
Thanks
Duane
Any ideas.
Thanks
Duane
