scubapro820 said:
Ok now Im on my desktop, so I used 1/8'' aluminum to build an adapter plate to the rear of the boat. I still have to make the support for the pump in the rear. When I get my coupler in the mail I have to mount the engine. Im thinking about using 1/8'' or 1/16th'' aluminum 2x4 or 1x3 tubing to make a cradle type mount for the engine.
Right. A rail design, where you run the tubing longitudinally, under each side of the engine, for the motor mounts to bolt into. You really should use 3/16" or even 1/4" wall thickness for the tubing, though. 1/8" is not going to be beefy enough, and 1/16" definitely won't be strong enough either. You also need enough material thickness to put the motor mounting bolts into. I believe the rule of thumb is to have thread engagement that is 3X the diameter of any given fastener.
So, if you're using 1/4" fasteners, your material thickness really should be 3/4" But I think as long as you use some 3/8" flat stock, welded to the top side of the tubing, at each point for the motor mount, then drill and tap through the flat stock as well as into the top of your tube, that gives you about 5/8" of thread engagement, which should be adequate.
I had some success using 5356 wire and a push mig setup the cabin on my boat was based on the coast guard design works pretty well for long river trips in minnesota. I use the boat to get to remote areas around the mississippi for hiking hunting and camping trips.
5356 wire is what you should be using for any aluminum that will be used in water, particularly in salt water. 4043 is not as corrosion-resistant as 5356. Also, the 5356 is a much harder wire, which is a good thing if you're using a conventional MIG, instead of a spoolgun. Trying to run the softer 4043 alloy wire through a regular MIG is just asking for a PITA, even if you try using a teflon liner, it's going to bird-nest at the drive rolls.
as for steering there is a push pull setup from teleflex for jet boats that im looking at, does anybody know if the steering wheel and bezel that are teleflex are standard and can be reused. and another thing the jet nozzel looks like it moves 4.25 inches. the kit from teleflex moves 3.5 . I really do want to use a steering wheel for control so I need some help/ ideas here
OK, Teleflex makes 2 different helm controls for jet boats. One is configured to be 135 degrees from lock-to-lock. The other is configured for 270 degrees from lock-to-lock. I used the 270 degree on my boat.
The cable you need to use is a Teleflex CC694 series (I think they've changed that to CC6400 recently) Anyhow, this cable has 4 inches of travel, and it uses 5/16" x24 threaded ends, much heavier duty than the CC633 series cable, which uses 10-32 threaded ends.
The CC6400 cable has one end with bulkhead nuts and washers. So, for this end, you just need to make sure that you position the cable where the full travel coincides with the full travel of the steering nozzle. Depending on the set-back of your pump, you may either have to in-set the bulkhead, or move it out, to make the setup work correctly.
This sounds complicated, but basically all it involves is using a short length of round aluminum tubing with an end cap welded into one end, with a hole through the center for the cable to pass through. The tubing ID needs to be large enough to accommodate the cable, with the washers and nuts installed, and it needs to be a little bigger, to allow for a deep well socket to fit in there to tighten the nut (a modified 7/8" oxygen sensor socket works great for this)
Even if you don't have to inset the cable, this socket still works great for cable removal. Basically, modify the O2 sensor by cutting it off close to the end, then splice in a 6" length of pipe of equal diameter.
Anyhow, back to the bulkhead adapter pipe. Use a hole saw and cut a hole through the transom for the aluminum pipe to fit into. Then, with the cable installed into the pipe, and the pipe going through the hull, you install the ball end fitting on the cable and connect the cable to your steering nozzle. Checking full left travel (cable travel extended) then full right travel (cable travel retracted) you move the bulkhead adapter pipe in, or out, as necessary, then tack it in place. Remove the cable from the adapter tubing, and weld the tubing into the transom. (I used square tube for mine....would have been a helluva lot easier with round tubing now that I think about it.)
Here's a few pics to illustrate what I'm trying to explain:
OK, in this one, you see that the cable is actually in-set into the hull, into the piece of square tube. This is a shot of the reverse gate cable. The steering cable is set up in a similar manner.
This is what it looks like from outside the boat:
A shot of the steering cable extension from the transom, with the ride plate removed:
It may be a little difficult to see these clearly, because everything is coated with black anti-fouling paint.
Now for the helm.....
The other end of the cable is a little different, but it can be made to work in conjunction with the Teleflex jetboat steering helm. There is a fitting that comes with this helm kit, you'll need to drill and tap into this fitting for some stainless set screws to act as keepers for the cable, to keep it from slipping back and forth. (Let me know when you get to this step, I'll walk you through it)
You can see in this closeup shot how the SS set screws hold the cable sleeve in place.
And just for a little added security, I secured the cable like this:
Yep, those are hose clamps, placed around the cable body. I have a set on the inside, and a set on the outside of the console where the cable passes through. I suppose a bracket could be fabricated with some set screws to secure the cable body, and this bracket could be bolted to the inside of the console. And at some point, I may end up doing that. But I've had no issues with this configuration, so, if it ain't broke, don't fix it.
Again, this is the setup I've been using in my jetboat for nearly 7 years, and it works great. I can spin the boat in its own length at 30 MPH, and I'm talking about a 16 ft DuraCraft johnboat, not a specialized jetboat hull. My steering nozzle travels about 1/8" from full lock in either direction, and the travel on the XL1200 nozzle is about the same as your pump, nearly 4.5 inches.
Anyhow, that's my input for right now. Like I said, when you start getting into doing the modifications, let me know if you have any trouble, I know every idiosyncrasy of doing one of these builds, as I've done it not once, but twice. I can definitely save you some time and difficulty.
