Pruitt1222
Thats a very cool build you got going there man. Dont think you will have to worry about seeing another one like it at the ramp.
Ride_Klein said:Motor mount repair turned into more of an ordeal than I expected. This is why I love boats and boat projects. Nothing ever comes easy, but when you're done it feels so good.
Ended up needing to pull the expansion pipe, water box (muffler), and all the cooling hoses off to get to the darn thing. The aluminum platform I'd built came loose from the hull. I'd used some 3m VHB tape to hold it down during mock-up and forgot to rivet this one in. Not sure how I missed that, but glad it happened on a shake down run. On the other side, that VHB tape is legit. Held up for 3 pretty good test runs and about 300 miles of rough Texas back roads before it finally gave up the ghost.
When I pulled the expansion pipe off I noticed a small crack in one of the freeze plugs. I used a wire wheel to clean it up down to good clean aluminum and patched it up good. Forgot to snap pictures of it last night. Once again, thank goodness that motor mount let go. Helped me find a little crack that appears to have been there for a while.
Success on the registration front. The people in the Garland Office of the Texas Parks and Wildlife are perhaps the most helpful government employees I've ever met. Know their craft very well, are professional, thorough, and give you all the information you need before you get in there. Took about 15 minutes to get the title modified from an outboard to an inboard boat.
Also got the Raw Water Strainer in the mail the other day. I needed a 1/2" unit and this Jabsco one had the biggest bowl I could find. I'll get it installed before the next/final shake down run. Thanks to PSG for the recommendation. I was tempted to go without one, but his experience convinced me to order it. The test run this past weekend proved that it will be needed because the water box had a little junk in it from running shallow.
It is a Jabsco Pumpgard Model # 36400-0000
Ride_Klein said:Was a great weekend out on the lake. The boat will run very shallow, but you have to be committed. A wise man once said, "If you come off the throttle in 1 inch of water, you will have an afternoon's worth of pushing ahead of you". Fortunately we only made this mistake once.
The lakes I hunt are mostly muddy bottoms with stumps randomly placed beneath them. So long as we either idled through the rough spots or stayed up on the throttle we didn't have any problems with them. It made scouting a lot of water much easier than it normally is.
Had a chance to shoot a little video on my way back to the ramp. Apologies again for it not being the best video, but you get the idea of how shallow it will run.
[youtube]K_w9sxEYSVI[/youtube]
I can get on step in about 10" of water, and run in just an inch or two. It is a real blast.
Couple photos from the weekend.
A shot of the boat layout and the garage camo job I did. The camo was done with regular spray paint. Base coat of tan, then use a 1/2" piece of PVC pipe layed up against the hull and mist the Green, Brown, and Grey down the pipe to create a faded edge. Not the fanciest, but works for us.
Want to again say thanks for the help this site offers. Great group of people with a lot of great boats.
Special thanks to PSG. Your experiences really helped. The Raw Water strainer was a life saver this weekend. When we got stuck it let us use the jet to help "push" a little, but we would clog the filter in about 5 seconds. Simple fix by just emptying it out and start all over again. Really appreciate you sharing you build so I could borrow that engine saver from you.
PSG-1 said:Ride_Klein said:Was a great weekend out on the lake. The boat will run very shallow, but you have to be committed. A wise man once said, "If you come off the throttle in 1 inch of water, you will have an afternoon's worth of pushing ahead of you". Fortunately we only made this mistake once.
Haha, I got a kick out of that! Definitely a shallow runner. Don't know about you, but when I run across areas like this in my boat, it almost makes my hair stand straight up, it's a rush, for sure.
That's a good looking paint job. Neat trick with the PVC pipe, too.
Shot of the Camo from the Waterline. Still need to do the interior, but that will wait for the spring.
Limits of Teal. Normally we find more big ducks late in the season on big Texas Reservoirs, but this weekend it was all Teal all the Time. Won't hear any complaints from this captain. They taste darn fine.
Glad to see you are enjoying the rewards from all the hard work. There's definitely a certain sense of pride of ownership with something like this.
