MD_Electric_Bass
- Joined
- Oct 12, 2016
- Messages
- 16
- Reaction score
- 0
Hey everyone, first time posting here on tinboats. I've gotten a lot of info and ideas from the builds that have been posted previously. I recently picked up my first boat to build out for the electric only reservoirs here in Maryland. Like the title of the post says, it is an Alumacraft 1648 NCS Jon. I wanted something stable and comfortable for my daughters and wife while also being a solid fishing boat for my dad, brother, friends and I.
My current plans for the floor and decking are pretty simple. An extension off the existing front deck, 6 feet of floor laid on top of the ribs(with 1'1/2 polyethylene foam cut to size between ribs for floor stability and flotation), and another casting deck on the back. I only plan on doing 3 hatches, 2 in the front deck, 1 for batteries and the other for tackle, and one on the back to keep access to the plug. I'm planning to use .100 aluminum for the floor, .125 for the decks and aluminum angle framing. Planning on most, if not all pop-rivets, as I don't plan on drilling into the hull at all below the water line. Also want to do a small side console. Carpet or Hydroturf covering it all.
I also recently purchased a used Ray 48 volt electric outboard motor. It's in great shape and ran great during the testing, but I am debating if there is anything I should do maintenance-wise in order to ensure the outboard continues to function properly into the future.
The wiring is all sound and something that I can refresh if needed. The previous owner ran this as a 36 volt system with 3 12volt batteries in series. The manufacturer stated that the motor was produced as a 48 volt system, as all the speed controllers are rated 48 volt, PMC is 36-48volt and the motor itself labeled 36 volt(she also compared similar aged motors and the 48 volt systems with GE motors were labeled 36 volt...). I was planning to use this outboard as intended, with 8 6 volt batteries wired in series, using the 48 volt charger it came with.
I look forward to sharing my build with you all and welcome any and all advice and suggestions. This is my first boat and first build so Im sure there are things I haven't thought about or considered. Please help if you see me veering off course or see a better way of doing things. THANKS!
