I have a mv 1648 center seat side console and at the end of last years fishing season I was caught in a large storm with about 3 foot waves. Ever since then the boat started to leak. I never had the time to look at it till now.
There are 8 rivots leaking all on the same rib support. All are on the bottom none are leaking on the sides, nor is it leaking anywhere else on the boat. There is no weight forward on the center seat so Im thinking these rivots all started to leak cause of the wave impacts on the front of the boat and the rivots being flexed over and over. visually the leaking rivots do not sit as flush as the non leaking rivots.
Would the addition(battery,tank,ect,) of weight being moved forward and a 1/8 aluminum decking help reinforce the over all structure of the boat? It should reduce the front flex of the hull or am I missing something. Has anyone noticed any diffrence in the frequency of rivot leaks with decking? Thanks
