jimmy fins
dwaynesworld said:Jimmy, did you put any foam under floor?
No It might have blocked the hole in the ribs that the water runs down towards the stern. It seems to be strong enough for me, but you do get a little sag when you step between ribs. The thickness of the wood is small enough to form the floor to screw it flush to the ribs. Here's a crude drawing I did to help explain it for you hope it helps.
