Remington351
Hi Guys, I need some help with my 1980's Alumacraft Lunker rebuild. I need to replace the transom board, but am not sure how to remove the cap. The transom is a solid, single sheet of 3/16 aluminum with this 6 inch board at the top as shown. The cap seems to be spot welded to the transom. Do I dremel off under these indents? Air chisel? Drill? Other suggestions are appreciated. Thanks.
