Restrained
- Joined
- Aug 20, 2013
- Messages
- 60
- Reaction score
- 0
[url=https://www.tinboats.net/forum/viewtopic.php?p=331570#p331570 said:Ranchero50 » 07 Oct 2013, 22:33[/url]"]Looks like a good start. The Panfish always was one of my favorite designs. Open floor with enough room to work and play. Sadly Tracker builds cheap production boats and sell them at a premium. At least you can tell where the screw heads are by the rust.
Suggestions, go .100" max for you floor. You can probably get away with .062 if the frame span isn't over 16" or .80". 3/16" is way too heavy for the application.
For the foam I'd use the rigid panels and cut them to fit under the floor (as long as you have a lot more of it up high so the hull doesn't turn turtle it it sinks).
The floor supports are 13" on center. Figured 3/16" aluminum was way overkill but there's a good reason I chose it. I called a local metal supplier and each panel was over $200. I found a guy 10 minutes away that demolished a building and stripped out lots of aluminum floor panels. They are $25. each, and weigh but 22 pounds which is still way lighter than plywood wet or dry.
I planned on a trip to Home Depot to get the Foamular boards. I'll put the thickest material under the flooring that will fit.
I'm thinking that it may be wise to put something like weatherstripping on the tops of each flor suppor spar to isolate the aluminum panels and possibly rattles or squeaks, what do you all think?
What type of screw would you recommend for the flooring? I have thought about pre-drilling and countersinking each screw hole but if I could find a ss screw with a small head that might work as well. One that was powder coated gray to match the new carpet would be even better.
