robnet
Hello all my first post here. I have a 70s aluminum Gregor that I’ve been fighting leaks with. Patched a couple pin holes I found by filling the hull with water in the driveway.
However it still leaks quite a bit when out fishing. I filled again and noticed a lot of water leaking out from these 2 holes near the right side of the transom bottom corner. It’s only leaking from the right corner holes. What are these for and can I patch them to stop the leak? Thanks!
