Hi
I have a 1977 14' Duranautic offshore with 9.8 Mercury. I removed the old plywood (I replaced about 15 years ago). The aluminum behind the plywood had about 6 small holes less than 1/4"diameter.The rest of the 18 x 20 section had some gouges eaten in and wasn't smooth.
The questions I have are these.
After I clean the area, can I use a skim coat of a fiberglass re-enforced body filler to fill the holes and smooth the area then paint?
I’m going to use 2 pieces of ¾ plywood glued together primed and painted.
I’m going to attach the plywood to the boat with stainless steel bolts.
I will sand and paint the outside of the boat also.
If I put a piece of rubber roofing between the plywood and aluminum will this keep this from happening again?
Does this sound like it will work?
I think this happened because I used pressure treated wood the last time.
Newbie to this forum
Steve
Steve
