Turd Ferguson
- Joined
- Apr 2, 2019
- Messages
- 43
- Reaction score
- 0
Hey All,
Long time lurker and first time poster. Okay so to make a long story short, I purchased this 1988 Bass Tracker three years ago. Previous owner didn’t know the model, but from what I’ve researched I guess it to be a Pro V 16. Any help figuring that out would be appreciated. The boat came powered with a Mercury Classic 50, which I’ve found to be a reliable little motor at 45 HP. However, even after a re-prop, the boat maxed at 23 MPH which I was a little upset about.
I removed the motor last April to mount a 9.9 to fish some local tournaments (many lakes here in NJ are restricted to a 9.9 HP limit). In doing so I noticed that the transom was completely rotted out. So my transom repair turned into a full boat rebuild. It’s almost been a year since I started tearing into it and I haven’t made very much progress. It’s been tough to find the time but I’ve been chipping away at it.
So the boat has been completely gutted, power washed and now the building is starting. Getting all the old carpet glue off was a nightmare! I’ll post as many pictures as I can of the rebuild. However I didn’t take any before pictures which was very foolish of me!
I got the new transom in about two months ago. Didn’t take many pictures of the process but I’ll explain it here. The transom was 1.25” thick. I used 3/4 and 1/2 marine plywood, which I epoxied together and then cut to shape after creating a template. I then sanded the new transom piece and applied 3 layers of a penetrating epoxy. I then dry fitted the new transom and marked for holes. I drilled all of the holes out oversized and filled them with a thickened mix of epoxy resin. Once that dried, I fiberglassed both sides of the transom with 17 ounce biaxial fiberglass and an epoxy resin. Once all that was finished up, I set the transom in position and drilled all the holes. All new fastenings were 316 stainless carriage bolts with nylon lock nuts, and coated in 3M 5200 before installation.
For the tie down Ubolts I added a backing block of 1/4” G10 fiberglass. This should help tremendously to stiffen them up.
![ABED4247-5415-4F8B-8DC9-019FB51006F9.jpeg ABED4247-5415-4F8B-8DC9-019FB51006F9.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/85/85226-3340dc8805b813d9aa3251a26507a1fe.jpg)
![47A6A639-66CE-4F22-A08B-5FF8444C83D1.jpeg 47A6A639-66CE-4F22-A08B-5FF8444C83D1.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/85/85227-a5bde519f62abe49b9e8ff75eb90299a.jpg)
![32F8C6CB-CBD7-4D96-A46B-98A386F4FC2C.jpeg 32F8C6CB-CBD7-4D96-A46B-98A386F4FC2C.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/85/85228-653421744690e683e9c122a13436b9a5.jpg)
Before fully installing the transom I sanded the skin of the hull that transom sat against. I then gave it an acid wash and coated it with a spray on epoxy. Hopefully that will prevent any corrosion from continuing or occurring.
![48CFB5DF-DC76-42F9-8A5B-C1AF27D1B357.jpeg 48CFB5DF-DC76-42F9-8A5B-C1AF27D1B357.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/85/85225-ff017c2c1efbb67c8878628fdff31627.jpg)
Also, you can see in the pictures that I added an additional aluminum plate to the transom supports that tie into the hull. They seemed awfully small. I would’ve liked to replace them with beefier angle but I didn’t want to mess around with removing rivets through the hull.
Unfortunately I didn’t take too many pictures of the transom progress so the pictures leave a lot out. If you have any questions feel free to ask!
