FishinsMyLife
With the 20 lb line on a spinning reel, you really probably couldn't throw anything but big Zara Spooks. I use 20lb on my ocean rod and I am usually throwing bottom rigs with two or three ounces on the end. Also, if you invest in a quality baitcaster, you can throw a lot lighter weights than you think. I can throw a 1/8 ounce Mepps spinner for big bream and bass on my Shimano (Cardiff) with 10lb line. It may not go as far as it would on 4 or 6 pound mono on a spinning reel, but I can get a good amount of distance, and that baitcaster is far from the top of the line. I have never broken off on a baitcaster because of suddenly stopping my bait. Bad line? The only times I have gotten broken off involved bad line and drag that was way too tight. My bass spinning reel is used for dropshotting and awkward rigs like live bait (blah, blah, I'm going to hell for using live bait, I know :roll: ). Every other technique you mentioned, I can do on my baitcaster just as good and better than I can on a spinning reel. I fished all my life until 5th grade with spinning reels and then after I used a baitcaster, I never stopped.SMDave said:but I have used 20lb. mono on a bass spinning rod before... Try casting an inline spinner on a baitcast, then on a spinning outift with lighter line (or even the same!). .
