Rich27028
i have 2 -a 500 gph on a float switch and a 750 on a toggle on the console--
16ft lowe 30 yamaha-
CodyPomeroy said:I have one that operates on good ole man power.
https://www.cabelas.com/bilge-pumps-hand-bilge-pump-1.shtml?WT.tsrc=CSE&WT.mc_id=GoogleProductAds&WT.z_mc_id1=00048807&rid=40&mr:trackingCode=D55E84C8-958E-DF11-A0C8-002219318F67&mr:referralID=NA&mr:adType=pla&mr:filter=43601101631&mr:match={matchtype}&mr:ad=19135902671&mr:keyword={keyword}
RivRunR said:I have a 1000 on a console switch, a 500 float (also on a console switch), plus a manual hand pump.
Overkill? Maybe.
Peace of mind? Yep.
PSG-1 said:If anyone is curious about whether or not they have an adequate system....here's how you find out.
Measure the length, width, and depth of the inside of your boat, then calculate cubic feet.
Then, determine the number of gallons per cubic ft. (I forget what it is) and multiply by the number you came up with from your boat's dimensions. This is the amount of gallons of water your boat could hold after being swamped.
Then determine your bilge pump's GPH (don't forget to account for pressure/volume loss from pumping head height....roughy 1 ft for a johnboat)
