- Joined
- Oct 1, 2011
- Messages
- 453
- Reaction score
- 230
- LOCATION
- SoCal
I would like to add a bow mounted TM. 12V/55 with GPS as I like the anchoring function and key fob remote.
NOTE 1: Previous owner to me added two 50# lead weight bags to forward-most area of bow under the forward-most small bench There is no foam under this small bow bench. I believe it there for hull and bow rigidity. The previous owner added this weight so the boat could get on plane quicker and smooth out the ride. Result: The boat rides smooth and gets on plane quickly, but I don't know what it was like before the weights, I can only assume it was not as nicely balanced as it is now.
I currently have a 12V transom mount TM, but want the bow mounted one ( for reasons mentioned above) AND so the weight bags can be removed and restore the 100# (from bags removed) with the TM and single 12V group 27 battery.
My dilemma is where to mount the single 12V battery? I would like it to be as low as possible, as forward as possible, secure, and not damage any of the hull or stringers from a floor it rests on.
NOTE 2: My front floor (factory floor) is behind the forward-most bench, is made of aluminum, and rests on the sides of the hull. Over time, the alum edges have created a detent in the side of the hull. I know this would be a logical and easy place to mount a battery, but I don't think adding a 60# battery to this front floor would be wise, as the edges are severely rubbing against the hull. (This is discussed in another thread from today).
The V shape of the hull and steep bow angle leave few options for creating a flat floor to mount battery.
What other options are there? Any pics of what you have done?
Thanks!
Thanks!
