New River Rat
nccatfisher said:The transom saver is bungee corded around the LU you hit a pot hole and the motor jumps up and the transom saver comes with the motor when it flies up and it comes off the frame of the trailer and motor slams down all the way to the bottom of the tilt setting as the transom saver is no longer attached at the bottom.New River Rat said:Stumpalump said:Transom savers with manual tilt are OK until motor bounces off the saver and hits the street.
Just being curious, how could this happen? I've used that exact set up for 20 years and just can't see what you mean.
muskiemike12 said:You can get a transom saver that is pinned to the trailer frame and not just resting in the roller. This will eliminate the jumping off issue.
I got what muskieMike said. I never thought it was good to do anything but attach the saver to the frame. If my frame was that much off, I'd be looking to find a better fit.
