rusmir
i think im gonna do the sam e thing to my boat like u did .. nice job
rusmir said:i think im gonna do the sam e thing to my boat like u did .. nice job
damifinowfish said:That turned out great. Your project is what I've been playing withon paper for my boat. One question how did the durabak look on your wood floor? Did you have to do anything to the wood for prep?
Thanks
Damifinow Fish
RBuffordTJ said:jsharp said:hey i love your boat i have a few questions for oyu how did you do the suports under the front deck and how tall is the front deck love the idea was thinking of borrowing for my boat but wanted some more info from you on how you did your suports in the front under the deck thanks for your info
Hey J,
The way I did the front was to take a line level on a string, place it on top of the front cross support on the boat floor, where it makes it upswing, then run it straight back to the bench seat to find the level height. Once that was marked on the bench seat I knew where to cut to run the plywood flat forward to rest on that front rib. We cut the seat (pics in first post) and we only had a couple inches, maybe 4 or so max, between the bottom of the deck and the floor, so I put floatation foam down to fill the void completely all the way forward. There are no supports under there but it feels rock solid and then we screwed it down into that front rib brace to hold it on the front, and to the created braces on the cut out seat in the back.
It feels rock solid, no flexinging at all and still allows for drainage down the chanels on the bottom if water comes in from rain or over the sides. With the deck not having much to span in height or length there was no use framing something up, and I am 250+ and it doesn't give at all with me walking or sitting on it.
Bufford in Orlando
RBuffordTJ said:I used a simple builder's foam board from Home Depot. All your doing is adding something to help it float if it flips or tries to sink and that stuff works fine for that.
Bufford in Orlando
Arkdave said:Man that is one good Idea, I looked all over the place, Trying to find something Round to fit in the PCV Pipe.
To use in the corners, Ended up just using a standard PVC ell in there,
But The Ell wants to pop apart on me, Mind Telling Me if you got the Ladder Stabilizer at Lowes or H.D. ?
Thanks =D>
perchin said:I like this way, but I think this one below would be stronger when the boat runs into them.
https://www.tinboats.net/forum/viewtopic.php?f=49&t=12764
