What's up guys?
I'm in the market for a 10-15 HP 4-stroke, and a 2008 Nissan just showed up on Craigslist less than a mile from my house. The only (potential) problem is that it hasn't been started in 3 years, and I have no way of confirming it was stored properly.
I assume that...
- Carb likely needs cleaning/servicing
- Gas should be drained and refilled
- Check spark plugs, and clean/swap as needed
- An oil change might be a good idea?
Am I missing anything?
Would it be a bad idea to try to start the thing before doing about of the above?
In other words, should I insist on seeing the motor run before buying it, or do I risk damaging the motor if I start it without servicing first?
Any general tips for this situation?
Thanks in advance!
Cheers,
Alex
I assume that...
Thanks in advance!
Cheers,
Alex
