I have a question on a short shaft motor made into a long shaft. A friend of mine bought a 15 hp Johnson motor this week and after he got it he found out that it was a long shaft motor. I had him get the aluminum angle and I made him a jack plate. He put this jack plate on today and mounted the motor. He adjusted the jack plate so that he has the same as a 20 inch transom. On his motor with it mounted the plate just above the prop hangs below the bottom of the boat but where the extension is in the motor there is another flat plate made into the motor shaft and it sits even with the bottom of the boat. He has the extension plus the lower unit the bottom of the boat. Is this right or will it cause problems when he uses it? Thanks Ivan
