Most codes on the cars are tripped by specific scenarios. For instance. I got a code for my catalytic converter on my forester. It always happened on the highway and no where else. The car was purchased used from a dealer and had a 60 day warranty. I was not going to pay for a new Cat. So they check it and cant find anything twice. Reflashed the computer with new Subaru firmware. Took it for rides around the dealer. No luck. It will also go out after a few starts of the car. By this time i got the factory manual. Sure enough for every code there is a driving scenario used to replicate the code error if you have one. In my case. If you get this code to verify it you need to drive over 50 mph for at least 10 minutes before it will trip. I explained this to the dealer and they fought back a little. So I told them I would bring them a copy of the factory manual so they know how to check for it. They didn't like to hear that. Sure enough they take it on the highway and find the problem. Bad catalytic converter. Which cost them $1000.
What i am getting at is the factory manuals have details like this. You could be just going in the right speed range, load on motor is just right and the sensors in the correct sensing mode and you trip the code because of those factors at that location. It may have nothing to do with construction, meth labs, pot smokers or pig smokers. Just the conditions and parameters on the cars systems at that time. Makes it hard to diagnose for anyone if thats the case. Only way would be to use a data logging scanner to see whats going on with the sensors and motor loads just before it trips. These types of repairs get very expensive at dealers because of labor.
My suggestion: get a copy of the actual factory shop manual and see if there is a procedure to replicate this code and what parameters affect it.
