crimping or soldering lugs and terminal ends
timsmcm
what is the best tool for crimping 8 and 6 gauge wire? or do you just like to solder the ends on? My small crimping tool will not do anything bigger than 10 gauge wire.
I don't know if it was right but I used a torch(acetylene) for 6 gauge.Didn't think I'd get the wires hot enough with a soldering gun.
I do both but you need a better crimping tool. Lowes has one in the electrical department. It's longer than the small ones and much heavier. I just crimped several 6 and 8 gauge and it works very well.
Can you tell me what tool that you got from lowes I have looked at two lowes and can not find it and the workers that are there do not know what I am talking about
This link will show you what it looks like. I couldn't find it online at Lowes but thats where I bought it. It was under $20 so it's not a channel lock brand but it's the same type.
https://www.amazon.com/Chanellock-Crimping-Plier-Cutter-Insulated/dp/B000189GWY
this is what i have nothing like 6 tons of pressure to insure a solid connection...
https://www.e-photon.com/Catalog/HUSKIE-TOOLS/REC-CN558;jsessionid=0a010b421f43ac7a9aa989a84996a711fdb5368cc331.e3eSc38TaNqNe34Pa38Ta3aKaxf0
one of the perks of the job
I have a pair like in Dinks link. Different brand, but same design. You can crimp with a large pair of pliers as long as you dont just crimp it flat. It must be bent in at some point so the crimp can reduce in size. If you ever plain on crimping more than twice, get a good crimper.
I crimp and solder every wire connection. Get the wire hot and sweet the solder in like copper plumbing.
that crimper will only go down to 10 awg. I need some thing to crimp 8 t0 6 awg wire and lugs
you can use bolt cutters if you have a pair... there is actually a notch under the bottom side for that
You can also use a punch and a hammer, then use self-fusing electrical tape or a ton of electrical tape
when you solder and crimp do you crimp the lug first then solder or the other way around and which solder do you use? Is standard lead tin solder with rosin core ok like the stuff you get at radio shack? And also can you use a butane torch to do the sweating? I have sweat lots of copper plumbing but no electrical. I have soldered lots of electrical with an Iron though, but dont think my iron will get hot enough for big lugs
I am using a soft point nosed punch and then solder works like a charm. Sweat it just like copper pipe.
I use lugs to connect 8 gauge wire.
file.php
Look for them in the electrical department.
I also use die-electrica grease on all my connections. It stops corrosion and I dont need to spend the time soldering/shrink wrapping every connection. Look for it in the electrical section too. Also use it on all your light bulb sockets, truck, trailer, and boat. I never have trouble with flickering lights, or corrosion.
Crimp then solder.
Rosin core ok.
I use small butane torch for everything.
