Tumble*Home
- Joined
- Feb 11, 2025
- Messages
- 17
- Reaction score
- 14
- LOCATION
- Port Charlotte, Florida
Forgive me if I hv posted in the wrong place and set me straight. This is my first time other than the introduction.
I rescued this little vessel from a back yard in SWFlorida. She was ignored covered by tall grasses and full of old rainwater and leaves. The owner inherited her from a Michigan grandfather and had no interest in the boat. We traded for artwork. She, the former owner, had the most wonderful bouncy curls hence the name Curly…
After 4 years I finally am ready to embark on a mid level restoration. Curly needs a visit to the spa. She deserves it and has waited patiently for me. My intentions are to make her pretty again to the best of my ability. Then we will adventure together up the Florida rivers and watch birds and alligators.
I will need guidance from time to time. I already have learned a lot from you people, so thank you for that.
Age? She is a “F” series. She had a registration sticker as old as 59 from Michigan.
Notable:
1: she has a pair of Aluminum oars!!!! So excited to buff those up.
2: her wheel is so close to the front bench seat it would be impossible to run her from there? Totally baffled on that one.
3: she has a gazillion holes drilled in all over for who knows why ( above water line thankfully)
4: she has very little stainless, screw-wise and many screws are either rusted out or completely corroded.
5: yesterday I discovered a broken pill bottle. the cap was screwed horizontally (corroded) just under and inside front dash area. Most of bottle was cracked off. Hidden key or what else?
6: there are 3 sets of oar locks. One is so far aft that it would not hv been practical?
My plans:
1: Replace transom woods.
Q: Does the outter piece have to be ply? Can it be a solid? And if ply does it hv to be marine or even exterior if I do 3 coats of spar?
2: inside transom wood 1”. Looking for a beautiful hardwood. Recommendation?
3: painting the stripe over rub rail (where numbers are) an aqua color. The paint is Total Boat Wet Edge. I called them and they recommended Interlux 200E primer. Interlux 333 brushing thinner if necessary. (MarineMaxx)
Q:Sand in between? 320? Thoughts? Brush or roll? I am leaning to roll for fear of brush marks.
4: install floor boards and cover with marine flooring mat.
5: trailer … pretty rough
Thanks for any thoughts, Melissa
Notable:
My plans:
